Siebel Installation Guide for UNIX > Additional Postinstallation and Configuration Tasks > Starting the Siebel Gateway Name ServerIf, during configuration of the current release, Siebel CRM version 15.0, you selected manual start for the Siebel Gateway Name Server, then you must make sure that the Siebel Gateway Name Server is started when you do any of the following:
NOTE: It is recommended that you review the Siebel Gateway Name Server log files, which are found in the Related TopicsTo verify that the Siebel Gateway Name Server has started
To configure the Siebel environment shell script to source automatically whenever a Siebel administrator logs on, specify the shell as the default for administrator accounts. Then, add this command to the startup file for the administrator's account. To verify that the Siebel Gateway Name Server started successfully and is running
| Siebel Installation Guide for UNIX | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
