Siebel Installation Guide for Microsoft Windows > Additional Postinstallation and Configuration Tasks > Preparing to Run Siebel Server Components > Obtaining Updated Siebel Repository FilesUpdated Siebel Repository files (SRF files) are available for download from My Oracle Support, using part number 22145965. These updated SRF files correspond to repository updates in the Siebel database for Siebel Innovation Pack 2015, Patchset 5 or later (version 15.5 or later). The SRF files are available for all of the supported Siebel languages. After you obtain the updated SRF files, copy them to applicable Siebel Server and Siebel Web Client installations, where appropriate. After you install Siebel Innovation Pack 2015, Siebel Patchset 5 or later, you require the updated SRF files in the following cases:
NOTE: Siebel Innovation Pack 2015, Patchset 5 or later includes some optional features that involve changes to the Siebel Repository. These features are already included if you install a new Siebel database after installing Siebel Innovation Pack 2015, Patchset 5 or later. For an existing installation of Siebel Innovation Pack 2015, if you want to use these features, you must run Incremental Repository Merge after installing the patchset release. (If you have already run Incremental Repository Merge for Patchset 5 or later, then you do not need to run it again for subsequent patchset releases.) For more information about Incremental Repository Merge and database upgrades, see Siebel Database Upgrade Guide. For information about installing Siebel Patchset 5 or later, see Siebel Patchset Installation Guide for Siebel CRM, 1614310.1 (Article ID) on My Oracle Support. This topic is part of Preparing to Run Siebel Server Components. Related Topics |
| Siebel Installation Guide for Microsoft Windows | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
