Siebel Installation Guide for Microsoft Windows > Additional Postinstallation and Configuration Tasks > Additional Tasks for the Siebel Web Server Extension and the Web Server > Configuring the Default HTTP and HTTPS Ports for the Web ServerThe default HTTP and HTTPS ports for the Web server are port 80 and 443. When you deploy SWSE onto the Web server, and if you want to use nondefault port numbers, then use the following procedure to configure these ports. The HTTP and HTTPS port numbers specified in the eapps.cfg file apply to the virtual Web site that you are using for Siebel Business Applications. For any custom virtual Web site name, the port numbers that you specify cannot be the same as the corresponding port numbers that are already in use for Default Web Site. For more information, see Configuring the SWSE Logical Profile. For information about using port numbers in secure deployments and about configuring Transport Layer Security (TLS) for Siebel CRM, see Siebel Security Guide. This topic is part of Additional Tasks for the Siebel Web Server Extension and the Web Server. To configure the default ports for HTTP and HTTPS
| Siebel Installation Guide for Microsoft Windows | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
