Siebel Installation Guide for Microsoft Windows > Cloning a Siebel Installation >
Properties Files Used in Cloning Operations
Table 22 lists several properties files that are provided for use with the Siebel cloning utility. Before you perform a cloning operation, copy an existing properties file, such as one of the following files, and edit the copy appropriately for your operation to create or deploy a clone. TIP: Retain the original properties files, and do not modify them. Edit only copies of the properties files for use in your cloning operations. You can also save multiple versions of any file with some of the settings that you typically use, to serve as templates for future use.
Table 22. Siebel Cloning Utility Properties Files
windowssource_ses.properties |
Windows |
Clone |
Siebel Enterprise Server |
windowstarget_ses.properties |
Windows |
Deploy |
windowssource_swse.properties |
Windows |
Clone |
Siebel Web Server Extension |
windowstarget_swse.properties |
Windows |
Deploy |
Related Topics
Properties File Settings for Cloning an Installation
