Siebel Installation Guide for Microsoft Windows > Installing the Siebel Database on the RDBMS > Installing the Stored Procedures and User-Defined Functions on IBM DB2On IBM DB2, after installing the Database Configuration Utilities, you must copy stored procedures and user-defined functions (UDFs) from the Database Configuration Utilities installation to the DB2 database server. Any method that transfers the necessary files to the correct location on the database server is acceptable. To copy the stored procedure code, complete the procedure that follows. Use the steps appropriate to the operating systems for the Database Configuration Utilities and the RDBMS. For information about how to perform basic IBM DB2 tasks, see the Quick Beginnings guide from IBM. To copy and install the stored procedures and user-defined functions
| Siebel Installation Guide for Microsoft Windows | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
