Siebel Installation Guide for Microsoft Windows > Installing the Siebel Database on the RDBMS > About Installing the Siebel Database > About Adding a Language to an Existing DatabaseAdding a language to an existing Siebel database installs seed data to support that language. After the database is initially installed with the primary language, each additional language must be installed separately using an add-language operation. To add a new language to previously installed Siebel Business Applications, you must have installed its Siebel language pack on the installed Siebel Server, using the Siebel Enterprise Server installer. See also Installing and Deploying Siebel Business Applications with Multiple Languages. After adding a language, you must import the Siebel Repository for this language. For more information, see Importing a Siebel Repository Manually into the Siebel Database. After you have added a language to the Siebel database, your seed data is multilingual. You must enable the multilingual list of values (MLOV) capability for Siebel Business Applications, and you must enable individual LOVs associated with the language. For more information, see:
This topic is part of About Installing the Siebel Database. |
| Siebel Installation Guide for Microsoft Windows | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
