The Siebel Web Server Extension Configuration Wizard (or SWSE Configuration Wizard) is the Configuration Wizard associated with this component. Use this wizard to configure the physical SWSE. Before configuring the SWSE, you must have created an SWSE logical profile using the Siebel Enterprise Configuration Wizard. Run this wizard on the Siebel Gateway Name Server computer. (You installed this component using the Siebel Enterprise Server installer.) Then run the SWSE Configuration Wizard on the Web server computer. (You installed the SWSE using the SWSE installer.) The associated Windows shortcut for the SWSE Configuration Wizard is named Siebel Web Server Extension Configuration. The shortcut runs a command similar to the following: C:\siebel\15.0.0.0.0\sweapp\config\config.bat -mode swse
