Siebel Installation Guide for Microsoft Windows > Installing Siebel Web Clients and Siebel Tools > Installing and Using the Siebel Sample Database > About the Siebel Sample Database ConnectString ParameterThe value of the ConnectString parameter in the [Sample] section of the application configuration files, such as uagent.cfg for Siebel Call Center (located in ConnectString = C:\siebel\ You can use the same sample database with Siebel Tools if you edit the ConnectString parameter in the tools.cfg file so it uses the same value, as described in Using the Siebel Sample Database with Siebel Tools. NOTE: This information does not apply to the Siebel Sample Database that uses Oracle Database XE, as described in Installing the Siebel Sample Database That Uses Oracle Database XE. This topic is part of Installing and Using the Siebel Sample Database. |
| Siebel Installation Guide for Microsoft Windows | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
