Siebel Installation Guide for Microsoft Windows > Installing Siebel Web Clients and Siebel Tools > Installing and Using the Siebel Sample Database > Installing the Siebel Sample Database That Uses Oracle Database XEWhen you install Siebel Innovation Pack 2015, Patchset 5 or later for Siebel Web Client (Mobile Web Client), you can install the version of the Siebel Sample Database that uses Oracle Database XE as the database platform. Use the procedure in this topic to install Oracle Database XE and the sample database for Siebel Web Client. Use this Siebel Sample Database in place of the sample database that was originally provided with Siebel Innovation Pack 2015 (Siebel CRM version 15.0), for which installation is described in Installing the Siebel Sample Database That Uses SAP SQL Anywhere. To be able to install this sample database, you must have included Oracle XE Sample Database, as well as Siebel Web Client, when you created the Siebel network image for the patchset release. For more information, see About the Siebel Network Image. The information in this topic complements the existing documentation for installing the applicable Siebel Patchset release. For more information, see Siebel Patchset Installation Guide for Siebel CRM, 1614310.1 (Article ID) on My Oracle Support. See also About Siebel CRM Releases. NOTE: With Siebel Innovation Pack 2015, Patchset 5 or later for Siebel Tools, you can also install the local database that uses Oracle Database XE. For more information, see Installing Oracle Database XE for the Local Database for Siebel Tools. However, you can install Oracle Database XE for only one of these databases on the same computer: either the local database for Siebel Tools or the sample database for Siebel Web Client. If one of these databases is already installed, then this database's DBF file is overwritten if you install the other database. NOTE: For Siebel Innovation Pack 2015, the local database for Siebel Tools and the sample database for Siebel Mobile Web Client can use either SAP SQL Anywhere or Oracle Database XE. The local database for Siebel Mobile Web Client uses SAP SQL Anywhere. SAP SQL Anywhere is not available for new deployments after September 2015. For more detailed information on how this change affects Siebel Tools and Siebel Remote, see Siebel Release Notes on My Oracle Support for Innovation Pack 2015 (Doc ID 1996273.1). When you specify to install the sample database, Oracle Database XE is installed silently: no screens are displayed for the Oracle Database XE installer itself. If Oracle Database XE is already installed for any reason, then it is not installed again, but the sample database is still installed. If Oracle Database XE was previously installed for any non-Siebel use, then you must uninstall it before proceeding. If you installed the Siebel Patchset release for Siebel Web Client, but did not install the sample database that uses Oracle Database XE, and you later decide to install this sample database, then you can do so by uninstalling this Siebel Patchset release, and then reinstalling it with the sample database option selected. NOTE: Oracle Database XE and the sample database are not uninstalled when you uninstall the Siebel Web Client software, in either a full uninstallation or a rollback uninstallation. For information about uninstalling Oracle Database XE, see Uninstalling Oracle Database XE. Optionally, you can install the Siebel Patchset release for Siebel Web Client, with Oracle Database XE, in unattended mode, as described in Installing Siebel Web Clients and Siebel Tools in Unattended Mode. To install and use Oracle Database XE, you must have the 32-bit Oracle database client installed on the client computer. For more information, and for the version of Oracle Database XE that is installed with Siebel CRM, see the Certifications tab on My Oracle Support. See also the documentation for Oracle Database Express Edition on Oracle Help Center. This topic is part of Installing and Using the Siebel Sample Database. To install the Siebel Sample Database that uses Oracle Database XE
Related TopicsRelated Books |
| Siebel Installation Guide for Microsoft Windows | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
