Siebel Installation Guide for Microsoft Windows > Verifying and Troubleshooting Your Installation > Verifying Installation for the Siebel Web ClientAfter installing the Siebel Web Client software as a new installation or as a migration installation, review the installation log files, verify the version number of your installed software, and review the Siebel Web Client directories and files that now exist under the SIEBEL_CLIENT_ROOT directory that you specified during the installation. This topic contains the following information:
Related TopicReviewing the Installation Log Files for the Siebel Web ClientAfter installing the Siebel Web Client software, review installation log files to verify that all of the components installed successfully, particularly if you experienced any difficulties with the installation. The log files are created in the following directory:
The relevant log files for an installation session are named installActionsdate_time.log file. In the file name, date_time represents the date and time when the file was created; for example, installActions2015-07-02_10-28-04PM.log. For each set of files created, the oldest and largest log file generally represents the Siebel module being installed. This topic applies to the Siebel Web Client installation, but not to the Siebel Sample Database installation. Verifying the Installation Version Number for the Siebel Web ClientAfter installing the Siebel Web Client software, verify the version number of the installed Siebel software. This topic applies to the Siebel Web Client installation, but not to the Siebel Sample Database installation. To verify the installation version number for the Siebel Web Client
Reviewing the Installation Directories for the Siebel Web ClientThe following minimum directories are created for a Siebel Web Client installation. These directories, the files and subdirectories they contain, and various other files are created in the directory that you specified during the installation, such as NOTE: The SIEBEL_CLIENT_ROOT. The directory for the Siebel Web Client installation, such as bin. Contains all of the binary files (*.exe, *.dll, and so on), configuration files (*.cfg), user preference files, and language-specific files. cfgtoollogs. Contains installation log files. charts. Contains files for generating charts. isstempl. Contains templates for the Customer Order Management CDA application and engine files for newly created projects. lex. Contains dictionary files used by the spelling checker. local. Where the local database is stored. locale. Stores language-specific files. log. Stores the log files from Siebel Web Client operations, such as synchronization. msgtempl. Stores message files used by the Siebel Web Client. objects. Contains compiled Siebel Repository (SRF) files and language-specific files. opatch. Files used by the oraclexe. The installation path for Oracle Database XE. This directory is created if you have installed that module for the Siebel Sample Database, as described in Installing the Siebel Sample Database That Uses Oracle Database XE. public. Contains HTML, ActiveX, Java, and JavaScript files, and image files used by the Siebel Web Client. sample. Contains the Siebel Sample Database. This directory applies to the SAP SQL Anywhere version of the sample database only. sqltempl. Contains SQL scripts. Do not modify these files. temp. Contains working report files. upgrade. Contains Siebel Anywhere upgrade files that have been retrieved by the user. webtempl. Contains Siebel application Web templates. Verifying ODBC Data Sources for the Siebel Developer Web ClientVerification of ODBC data sources for the Siebel Developer Web Client is similar to that for Siebel Tools. For information, see Verifying the ODBC Data Sources for Siebel Tools. |
| Siebel Installation Guide for Microsoft Windows | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
