Siebel Installation Guide for Microsoft Windows > Requirements for Installing and Configuring Siebel Business Applications > Requirements for Installing Siebel Web ClientsReview the issues and tasks in this topic before installing the Siebel Web Client, as described in Installing Siebel Web Clients and Siebel Tools. Administrative Rights for InstallationAdministrative rights are required for installation or uninstallation of the Siebel Mobile Web Client or Developer Web Client. For information about setting administration rights, consult the operating system manuals for the version of Microsoft Windows on which you are installing the Siebel Web Client software. For information about uninstalling Siebel Web Client software, see Uninstalling Siebel Web Clients or Siebel Tools. Directory Naming ConventionsBy default, the Siebel Web Client installer assumes an installation directory of If you must change the installation location to use a nondefault path, then use installation directory names that describe both the version number and the component being installed. The directory name can use any characters appropriate for Windows-compatible long file names, except that spaces must not be used in your install directory. In this guide, the directory into which you install the Siebel Web Client is often referred to as SIEBEL_CLIENT_ROOT. If you install into a directory other than the default, then make appropriate substitutions throughout this guide. CAUTION: Do not install other Siebel components, such as Siebel Tools, into the same directory where you have installed the Siebel Web Client, such as Related TopicsRequirements and Recommendations for Siebel Web ClientBefore beginning Siebel Web Client installation, review the requirements and recommendations for hardware, system software, and third-party software described in the Certifications tab on My Oracle Support. Restricted Support for Siebel Developer Web ClientThe Siebel Developer Web Client is not supported for end-user deployment. This Siebel Web Client type is supported only for development, troubleshooting, and limited administration usage scenarios. Database Connectivity Software for Siebel Developer Web ClientSiebel Developer Web Client computers connecting directly to the Siebel database must have the correct vendor-specific database connectivity software installed. See the Certifications tab on My Oracle Support. NOTE: The correct version of database connectivity software must be installed before you install the Siebel Web Client. For additional information, see Logging in to Your Siebel Application. When you have installed your database connectivity software, configure it as follows:
SAP SQL Anywhere Database No Longer ProvidedSAP SQL Anywhere is no longer provided for Siebel Innovation Pack 2015. You cannot use SAP SQL Anywhere for the local database or the Siebel Sample Database for new deployments. NOTE: For Siebel Innovation Pack 2015, the local database for Siebel Tools and the sample database for Siebel Mobile Web Client can use either SAP SQL Anywhere or Oracle Database XE. The local database for Siebel Mobile Web Client uses SAP SQL Anywhere. SAP SQL Anywhere is not available for new deployments after September 2015. For more detailed information on how this change affects Siebel Tools and Siebel Remote, see Siebel Release Notes on My Oracle Support for Innovation Pack 2015 (Doc ID 1996273.1). Oracle Database XE Sample Database RequirementIf you will use Oracle Database XE for the Siebel Sample Database, then, when you create the Siebel network image for Siebel Web Client, you must also include Oracle XE Sample Database. For more information, see About the Siebel Network Image. Using Oracle Database XE also requires that you have installed the 32-bit Oracle database client on the client computer. For more information, see Installing the Siebel Sample Database That Uses Oracle Database XE. Siebel Repository Files RequirementMake sure that you have the Siebel Repository files (SRF files) that are correct for your installed Siebel CRM version and the version of your Siebel database, such as Siebel CRM version 15.0. For the current release, updated SRF files are provided with new installations and migration installations of Siebel CRM. For migration installations, you must run Incremental Repository Merge, as described in Siebel Database Upgrade Guide, and recompile the SRF file. Other Third-Party SoftwareYour Siebel application might require some third-party software products to be installed on the client computer, for full functionality. For more information about third-party software, see the Certifications tab on My Oracle Support. For information about requirements for the Web browser environment for running Siebel Web Clients, see also Siebel System Administration Guide. NOTE: Remember to install on the client computers all of the software required to view any standard attachment types your Siebel Business Applications deployment might use. Chrome Browser UsersWhen using Siebel Mobile Web Client or Developer Web Client with Google Chrome as the default browser, make sure that no other instances of Chrome are running prior to starting the Siebel client. Closing Browser SessionsBefore you install the Siebel Web Client software, it is strongly recommended that you close any browser sessions on the client computer. For information about requirements for the Web browser environment for running Siebel Web Clients, see also Deploying Siebel Open UI and Siebel System Administration Guide. See also Enabling Siebel Open UI. |
| Siebel Installation Guide for Microsoft Windows | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
