Siebel Installation Guide for Microsoft Windows > Uninstalling Siebel Business Applications > Uninstalling Siebel Web Clients or Siebel ToolsThis topic describes how to uninstall Siebel Web Clients (Mobile Web Client or Developer Web Client) or Siebel Tools. Both full uninstallation and rollback uninstallation (a type of patch uninstallation) are described. With a rollback uninstallation for these modules, you roll back to the previously installed software version (such as Siebel CRM version 8.1.1 or 8.1.1.14, or Siebel CRM version 8.2.2 or 8.2.2.14). NOTE: If you installed Oracle Database XE for use with Siebel CRM, and you plan to uninstall or roll back Siebel Web Client or Siebel Tools, then it is recommended that you first uninstall Oracle Database XE. For more information, see Uninstalling Oracle Database XE. CAUTION: Before you proceed with any uninstallation task, review all of the information in About Uninstalling Siebel Business Applications, particularly the requirements and limitations. |
| Siebel Installation Guide for Microsoft Windows | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
