Siebel Installation Guide for Microsoft Windows > Uninstalling Siebel Business Applications > Uninstalling Siebel Web Clients or Siebel Tools > Uninstalling the Siebel Web ClientUse the following procedure to uninstall the Siebel Mobile Web Client or Developer Web Client in a full uninstallation. NOTE: If you installed the Siebel Sample Database (SAP SQL Anywhere version), then uninstall it before you uninstall the Siebel Web Client. Otherwise, you might be unable to uninstall the sample database. To uninstall the sample database, run the Siebel Uninstallation Manager from Add or Remove Programs in the Control Panel. NOTE: If you installed Oracle Database XE for use with Siebel Web Client, and you plan to uninstall Siebel Web Client, then it is recommended that you first uninstall Oracle Database XE. For more information, see Uninstalling Oracle Database XE. This topic is part of Uninstalling Siebel Web Clients or Siebel Tools. To uninstall the Siebel Web Client
Related Topics |
| Siebel Installation Guide for Microsoft Windows | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
