Siebel Installation Guide for Microsoft Windows > Uninstalling Siebel Business Applications > Uninstalling Siebel Web Clients or Siebel Tools > Uninstalling Oracle Database XEUse the following procedure to uninstall Oracle Database XE. You can use this procedure if you previously installed Oracle Database XE and the local database with Siebel Tools, or installed Oracle Database XE and the sample database with Siebel Web Client. Uninstalling Oracle Database XE also uninstalls the local database or the sample database. It is recommended that you uninstall Oracle Database XE if you installed it for use with Siebel CRM but then determine you will not use it. For example, you might uninstall Oracle Database XE if you uninstall Siebel Patchset 5 (version 15.5) and roll back to Siebel Innovation Pack 2015 (version 15.0). Uninstall Oracle Database XE before you uninstall or roll back Siebel Tools or Siebel Web Client. For patchset uninstallation (rollback), see Siebel Patchset Installation Guide for Siebel CRM, 1614310.1 (Article ID) on My Oracle Support. NOTE: When you uninstall Siebel Tools or Siebel Web Client, in a full installation or rollback uninstallation (including rollback of a patchset release, such as Siebel Patchset 5 or later), Oracle Database XE and the local database or the Siebel Sample Database are not uninstalled. In addition, the ODBC data source created for Oracle Database XE is not deleted in these uninstallation cases. As an alternative to the procedure below, you can uninstall Oracle Database XE from the Windows Control Panel. This topic is part of Uninstalling Siebel Web Clients or Siebel Tools. To uninstall Oracle Database XE and the local database or sample database
Related Topics |
| Siebel Installation Guide for Microsoft Windows | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
