Siebel Installation Guide for Microsoft Windows > Verifying and Troubleshooting Your Installation > Verifying Installation for the Siebel Web Server ExtensionAfter installing the Siebel Web Server Extension (SWSE) software as a new installation or as a migration installation, review the installation log files, verify the version number of your installed software, and review the Siebel Web Server Extension (SWSE) directories and files that now exist under the SWSE_ROOT directory that you specified during the installation. This topic contains the following information:
Related TopicReviewing the Installation Log Files for the SWSEAfter installing the SWSE, review the installation log files to verify that all of the components installed successfully, particularly if you experienced any difficulties with the installation. The log files are created in the following directory: The relevant log files for an installation session are named installActionsdate_time.log file. In the file name, date_time represents the date and time when the file was created; for example, installActions2015-07-02_10-28-04PM.log. For each set of files created, the oldest and largest log file generally represents the Siebel module being installed. Verifying the Installation Version Number for the SWSEAfter installing the SWSE, verify the version number of the installed Siebel software. To verify the installation version number for the SWSE
Reviewing the Installation Directories for the SWSEReview the physical directories created during the installation of the Siebel Web Server Extension (SWSE) on the Web server host to familiarize yourself with the locations of files such as the eapps.cfg and eapps_sia.cfg configuration files. NOTE: Additional top-level directories are created, which are parallel to the The following list shows some of the physical directories and files created after you install the SWSE on the Web server. Some of these directories are not created until the first login. In the list, lang represents each language that you have installed, such as
Reviewing the Log Files for the SWSESWSE generates one or more log files as a result of connection attempts with the Siebel Server. These log files reside in Depending on the logging level that you choose, these files record errors, warnings, and general information. Events such as Web server failures or invalid configuration of the SWSE are captured in these log files. Analyzing the log files can provide clues for troubleshooting SWSE problems. For more information about reviewing log files and monitoring Web servers and SWSE, see Siebel System Monitoring and Diagnostics Guide. | ||||||||||||||||||||||||||||||||||||||||||||
| Siebel Installation Guide for Microsoft Windows | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
