Siebel Installation Guide for Microsoft Windows > Configuring the RDBMS > Configuring a Microsoft SQL Server Database for Siebel Business Applications > Guidelines for Selecting a Language for Microsoft SQL ServerAs part of database creation, you must set the language characteristics of your database, even if you deploy in only one language. See also Planning RDBMS Installation and Configuration and Specifying the Locale for Siebel Business Applications. See also Verifying Installation for the Siebel Database. This topic is part of Configuring a Microsoft SQL Server Database for Siebel Business Applications. Sort OrderThe sort order is a characteristic that requires special consideration regarding the Siebel database. On Microsoft SQL Server, the sort order of a database instance is specified during database creation and defines the way in which the instance will sort character data. Although each SQL Server system database and each object within a database can have its own unique sort order, you must set the sort order at the database instance level only. Siebel Business Applications support for a given sort order depends both on the code page of the database and on whether it will be used in a development or a production environment. For more information about supported sort orders, see the Certifications tab on My Oracle Support.
| Siebel Installation Guide for Microsoft Windows | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
