Siebel Installation Guide for Microsoft Windows > Configuring the RDBMS > Configuring a Microsoft SQL Server Database for Siebel Business Applications > Guidelines for Creating the Microsoft SQL Server DatabaseUse a small, nonproduction environment for testing purposes. After you install the Database Configuration Utilities on the Siebel Server computer, as described in Installing Siebel Enterprise Server Components and the Siebel Web Server Extension you can modify the database table and index creation scripts to specify the tablespace names that you created for Siebel tables and indexes. For more information, see Guidelines for Overriding Microsoft SQL Server Default Tablespaces for Database Objects. For Siebel CRM language support, Unicode support, and legacy code page support, see 1513102.1 (Article ID) on My Oracle Support. This topic is part of Configuring a Microsoft SQL Server Database for Siebel Business Applications. |
| Siebel Installation Guide for Microsoft Windows | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
