Siebel Installation Guide for Microsoft Windows > Requirements for Installing and Configuring Siebel Business Applications > Planning Your Siebel Deployment > Managing Temporary Disk Space Required by Siebel Installers and WizardsThis topic is part of Planning Your Siebel Deployment. Siebel installer programs, the Siebel Image Creator utility, and Siebel Configuration Wizards all require the use of temporary disk space while operating. Disk space required varies by operating system. The location of temporary directories is specified using the TEMP and TMP environment variables. Set these variables the same: to a valid existing directory that contains adequate space. It is recommended that you periodically clear out the temporary directory that you are using. You might have to do this as part of resolving installer or wizard problems. On Microsoft Windows, the temporary directory used by default is The minimum disk space figures provided in this topic are general guidelines only. The specific amount of temporary disk space needed by a particular installation operation varies. If there is insufficient disk space, then the installer will notify you that more disk space is needed. CAUTION: A nondefault temporary directory name that you specify must not include spaces, in order to avoid problems associated with how Microsoft Windows handles long path names. Installers or wizards might fail if this problem is encountered. The user running the installer or wizard must have privileges that include write permission for the temporary directory. Table 25 shows the minimum disk space required by Siebel installers and wizards (by operating system), along with the default temporary directory locations. |
| Siebel Installation Guide for Microsoft Windows | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
