Siebel Installation Guide for Microsoft Windows > Requirements for Installing and Configuring Siebel Business Applications > Planning Your Siebel Deployment > Restrictions on Names for Siebel Enterprise and Siebel ServerThis topic is part of Planning Your Siebel Deployment. This topic describes restrictions to observe when planning the names that you will give the Siebel Enterprise and Siebel Server instances during configuration of Siebel Business Applications software. See also Restrictions on Host Names for Siebel Gateway Name Server and Siebel Server. Siebel Configuration Wizard tasks that specify or refer to the Siebel Enterprise name or the Siebel Server name validate for some of the following requirements, such as the 12-character limit. User input is validated in the wizard, unless you specify to skip validation, as described in Starting a Siebel Configuration Wizard. Observe all of the documented restrictions regardless of validation behavior. Siebel Enterprise Naming RestrictionsThe following restrictions apply to naming a Siebel Enterprise:
Siebel Server Naming RestrictionsWhen planning the names of Siebel Server instances within a Siebel Enterprise, the following restrictions apply:
| Siebel Installation Guide for Microsoft Windows | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
