Siebel Installation Guide for Microsoft Windows > Requirements for Installing and Configuring Siebel Business Applications > Planning Your Siebel Deployment > File and Directory Naming ConventionsThis topic is part of Planning Your Siebel Deployment. Use lowercase for all of the file names, directory names, path names, parameters, flags, and command-line commands, unless you are instructed otherwise. Directory names or file names cannot contain special characters, including periods, apostrophes, accents, number (pound or hash) signs, or ampersands. Underscores are acceptable. Spaces are not allowed for server installs on Windows (though the operating system might otherwise allow it). Spaces are acceptable for Siebel Web Client or Siebel Tools installs (on Windows). How This Guide Refers to Your Installation DirectoriesThis guide uses the following conventions to refer to the installation directories either created by the installers or to which users navigate to access files and executable programs. NOTE: The default installation directories shown in this guide for Siebel Enterprise Server components, Siebel Web Server Extension, Siebel Web Clients, and Siebel Tools are those for new installations of the current release, Siebel CRM version 15.0. Alternatively, your products might have been installed in different installation directories, such as if you originally installed them for a prior release. SIEBEL_ROOT. Generally, this refers to the main directory in which software for each Siebel Enterprise Server component has been installed. The installers for the Siebel Enterprise Server components install into the top-level directory, such as ORACLE_HOME. This refers to the same directory as represented by SIEBEL_ROOT. SIEBEL_HOME. The installation or root directory for Siebel Business Applications software in general (such as SIEBSRVR_ROOT. The installation or root directory for Siebel Server. By default, it is installed in SIEBEL_GATEWAY_ROOT. The installation or root directory for Siebel Gateway Name Server. By default, it is installed in DBSRVR_ROOT. The directory into which you install the Siebel Database Configuration Utilities (also called the Siebel Database Server). By default, these utilities are installed in SWSE_ROOT. The directory into which you install the Siebel Web Server Extension (SWSE). By default, it is installed in SIEBEL_CLIENT_ROOT. The directory into which you install the Siebel Mobile Web Client or Siebel Developer Web Client. By default, it is installed in SIEBEL_TOOLS_ROOT. The directory into which you install Siebel Tools. By default, it is installed in |
| Siebel Installation Guide for Microsoft Windows | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
