Siebel Installation Guide for Microsoft Windows > Requirements for Installing and Configuring Siebel Business Applications > Requirements for Installing and Configuring the Siebel Web Server Extension >
About the Siebel Web Server Extension
Siebel Web Server Extension (SWSE) enables communication between Siebel Web Clients and Siebel Servers. Siebel Business Applications are a family of Web-based applications that users access through a standard Web browser. Several components work together to deliver the applications to end users:
- Siebel Web Client. The Siebel Business Applications client that runs in the browser on the end user's computer and connects to the Web server. Particular Siebel applications might be deployed using Siebel Open UI, high interactivity, or standard interactivity.
For information about other Siebel clients, see the applicable documentation. For example, for information about the Siebel Mobile applications, see Siebel Mobile Guide: Connected and Siebel Mobile Guide: Disconnected.
- Web server. Client Web browsers connect to Web servers to access Siebel Business Applications. Supported Web servers and operating systems include:
- Microsoft IIS (on Microsoft Windows)
- Apache Web Server
- Oracle HTTP Server (on supported Linux operating systems)
- Oracle iPlanet Web Server (on Oracle Solaris)
NOTE: For more information about Web servers, see Installing the Web Server. For Web server platform support, see the Certifications tab on My Oracle Support.
Depending on the operating system of the Web server computer, specific Web servers are discussed in either the Windows version or the UNIX version of this guide (the Siebel Installation Guide for the operating system you are using).
For Web server and operating system tuning information, see Siebel Performance Tuning Guide.
- Siebel Web Server Extension (SWSE). A plug-in extension, installed on the Web server computer, that runs within the Web server and that communicates with the Siebel Web Engine (which is part of an Application Object Manager component, such as Call Center Object Manager) on the Siebel Server.
For SWSE installation instructions, see Installing the Siebel Web Server Extension. For SWSE configuration instructions, see Process of Configuring the Siebel Web Server Extension.
- Siebel Web Engine (part of Application Object Manager on Siebel Server). The Siebel Web Engine is part of the Application Object Manager component on the Siebel Server, such as Call Center Object Manager. The Application Object Manager provides access to Siebel Business Applications data and logic.
For information about the hardware, operating systems, Web servers, and Web browsers supported for Siebel Business Applications, see the Certifications tab on My Oracle Support.
