Siebel Installation Guide for Microsoft Windows > Requirements for Installing and Configuring Siebel Business Applications > Requirements for Installing and Configuring the Siebel Web Server Extension > Installing the Web ServerBefore installing the SWSE, you must install, configure, and start the supported Web server software on the designated computers. Follow the vendor documentation for this task, and also see relevant information in this chapter. For the best performance and scalability, put the Web server on a dedicated computer. Some Web server configuration tasks are also included in Additional Tasks for the Siebel Web Server Extension and the Web Server. This topic is part of Requirements for Installing and Configuring the Siebel Web Server Extension. Planning the Web Server TopologyBefore you install the Siebel Web Server Extension (SWSE), as described in Installing Siebel Enterprise Server Components and the Siebel Web Server Extension you must decide how to will distribute the Web servers and other components. Two basic methods are as follows:
Each deployment choice involves a trade-off. However, in enterprise-sized deployments, it is strongly recommended that you use a distributed node deployment for the following reasons:
For more information about Web servers and Siebel Web Server Extension, see About the Siebel Web Server Extension. See also Siebel Deployment Planning Guide and Siebel Security Guide. Installing Microsoft Internet Information Services Version 7 or LaterNative support is provided for Microsoft Internet Information Services (IIS) version 7 or later. You must include the ISAPI extensions. On Microsoft IIS 7.5 and later, you must enable 32-bit applications for the application pool defaults in order to support Siebel Business Applications. For more information about this issue, see 1340948.1 (Article ID) on My Oracle Support and see documentation from Microsoft. |
| Siebel Installation Guide for Microsoft Windows | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
