Siebel Installation Guide for Microsoft Windows > Uninstalling Siebel Business Applications > Process of Removing Configuration Data > Removing the Siebel Enterprise ConfigurationThe Siebel Enterprise Configuration Wizard removes a Siebel Enterprise that you have configured on the Siebel Gateway Name Server. NOTE: When removing a Siebel Enterprise using this wizard task, observe all of the documented requirements. Perform this task only if you have uninstalled, or removed all of the applicable configuration data for, all of the installed instances of SWSE and Siebel Server that depend on this Siebel Enterprise. When you perform this task, the Siebel Gateway Name Server must be running. This task might be useful in cases that do not involve uninstallation. This task is a step in Process of Removing Configuration Data. To remove the Siebel Enterprise configuration
Related Topics |
| Siebel Installation Guide for Microsoft Windows | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
