Siebel Installation Guide for Microsoft Windows > Uninstalling Siebel Business Applications > Process of Removing Configuration Data > Removing the Siebel Gateway Name Server ConfigurationThe Siebel Enterprise Configuration Wizard removes the Siebel Gateway Name Server service from the server computer, for a Siebel Gateway Name Server that you have installed and configured. NOTE: When removing a Siebel Gateway Name Server using this wizard task, observe all of the documented requirements. Perform this task only if you have uninstalled, or removed all of the applicable configuration data for, all of the installed instances of SWSE and Siebel Server that depend on this Siebel Gateway Name Server. Before you uninstall a previously configured instance of Siebel Gateway Name Server, you must perform this task. When you perform this task, the Siebel Gateway Name Server must be running. If this Siebel Gateway Name Server was not configured, then this task is not necessary before uninstallation. This task is a step in Process of Removing Configuration Data. To remove the Siebel Gateway Name Server configuration
Related Topics |
| Siebel Installation Guide for Microsoft Windows | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
