Siebel Installation Guide for Microsoft Windows > Uninstalling Siebel Business Applications > Uninstalling Siebel Enterprise Server or Siebel Web Server Extension >
Uninstalling the Siebel Web Server Extension
Use the following procedure to perform a full uninstallation of Siebel Web Server Extension (SWSE) software on a single computer. Uninstalling SWSE is similar to uninstalling the Siebel Enterprise Server. NOTE: If you use the method described in this topic to perform a rollback uninstallation, then you do not remove configuration data first. Use this method only when it is appropriate, so that you do not perform a full uninstallation by mistake. See also Rolling Back the Siebel Web Server Extension.
This topic is part of Uninstalling Siebel Enterprise Server or Siebel Web Server Extension. To uninstall the Siebel Web Server Extension
- Review all of the information in About Uninstalling Siebel Business Applications, particularly the requirements and limitations.
- Verify that you have performed any required tasks to uninstall other modules or remove configuration data.
NOTE: For example, before you uninstall an instance of Siebel Web Server Extension, you must perform the Configuration Wizard task to remove existing SWSE configuration data. For more information, see Process of Removing Configuration Data.
- Choose Start, Products, Oracle - EAPPWEB_HOME (or a similar Oracle home identifier), Oracle Installation Products, and then Universal Installer.
This action starts the instance of Oracle Universal Installer that was installed with your Siebel Web Server Extension installation.
- Click Installed Products.
- In the Inventory dialog box, select the Oracle Home value (for example, EAPPWEB_HOME) representing the installed instance of Siebel Web Server Extension software that you want to uninstall.
- Click Remove.
- Click Yes to confirm that you want to uninstall this Siebel Web Server Extension and all of its dependent components on the same computer.
The Siebel Web Server Extension software is uninstalled from this computer.
- In the Inventory dialog box, click Close.
- In the Oracle Universal Installer window, click Cancel.
- Restart your server.
Related Topics
Installing Siebel Enterprise Server Components and the Siebel Web Server Extension
