Siebel Installation Guide for Microsoft Windows > Uninstalling Siebel Business Applications > Uninstalling Siebel Enterprise Server or Siebel Web Server Extension > Uninstalling Oracle LDAP ClientUse the following procedure to uninstall Oracle LDAP Client software. Regardless of how it was installed, Oracle LDAP Client is not uninstalled when you uninstall Siebel Enterprise Server. Also, you cannot uninstall Oracle LDAP Client using the GUI interface for Oracle Universal Installer. Instead, you must use a command-line method to uninstall Oracle LDAP Client, whether it was installed with Siebel Enterprise Server or installed manually by running the Oracle LDAP Client installer directly. NOTE: This procedure assumes that you had installed Oracle LDAP Client with Siebel Enterprise Server, as described in Requirements for Installing Oracle LDAP Client. If you had installed Oracle LDAP Client manually, then the navigation steps might differ from what is shown in the procedure, depending on your installation location. This topic is part of Uninstalling Siebel Enterprise Server or Siebel Web Server Extension. To uninstall Oracle LDAP Client
Related TopicsRelated Books |
| Siebel Installation Guide for Microsoft Windows | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
