Siebel Installation Guide for Microsoft Windows > Uninstalling Siebel Business Applications > Uninstalling Siebel Enterprise Server or Siebel Web Server Extension >
Rolling Back the Siebel Enterprise Server
Use the following procedure to roll back the current release of the Siebel Enterprise Server software on a single computer and revert to the previously installed software version. You can do this only when you have installed the current release as a migration installation for an existing installation of Siebel CRM version 8.1.1.x or version 8.2.2.x. NOTE: To be able to roll back the current release and revert to a previous version, you must have retained the backup directory to which the previous installation was moved during the migration installation. During that installation, if the original Siebel Enterprise Server installation directory was named ses, then it was renamed from ses to ses_pre15.0.
NOTE: This topic describes only rolling back a migration installation, not rolling back a patchset installation. For patchset uninstallation (rollback), see Siebel Patchset Installation Guide for Siebel CRM, 1614310.1 (Article ID) on My Oracle Support.
This topic is part of Uninstalling Siebel Enterprise Server or Siebel Web Server Extension. To roll back the Siebel Enterprise Server
- Review all of the information in About Uninstalling Siebel Business Applications, particularly the requirements and limitations.
- Verify that the renamed original installation directory, such as
ses_pre15.0, exists.
- Stop the Siebel services for the Siebel CRM version 15.0 installation.
- Stop any active Oracle Configuration Manager services.
- You must use the correct rollback uninstallation method for your situation, as follows. For more information, see Requirements for Uninstalling Siebel Business Applications.
- If you originally installed Siebel CRM version 8.1.1 (using the InstallShield installer) and are now rolling back to Siebel CRM version 8.1.1 through version 8.1.1.7, then use the Oracle Universal Installer uninstallation option to uninstall Siebel CRM version 15.0. Follow the procedure described in Uninstalling the Siebel Enterprise Server, but do not remove configuration data. After performing this task, go to Step 10. (Step 6 through Step 9 do not apply in this case.)
- If you are rolling back to Siebel CRM version 8.1.1.8 or later or Siebel CRM version 8.2.2 or later, then use the manual steps that follow. Go to the next step. (Step 6 through Step 9 apply in this case only.)
- Delete the directory representing the current installation of Siebel Enterprise Server for the current release. For example, if the directory name is
ses, then delete this directory.
- Rename the backup directory representing the previously installed software to use the original installation directory name for Siebel Enterprise Server. Rename the original (renamed) directory, such as
ses_pre15.0, to ses (depending on your original installation directory name).
- Delete the program folder that was created for the current release, which contains the shortcuts for running the Siebel Configuration Wizards.
NOTE: After the rollback, in order to run the Siebel Configuration Wizards, you must use the wizard shortcuts for the version of the software that you rolled back to. Additional requirements apply to the post-rollback environment.
- If you rolled back to Siebel CRM version 8.1.1.8 or later or Siebel CRM version 8.2.2 or later, then verify the version number by using the
opatch command, as described in Verifying Installation for the Siebel Enterprise Server.
- Restart the Siebel services.
- If Oracle Configuration Manager was not configured before you performed a migration installation of Siebel Enterprise Server, then, after a rollback to the original installation, you must configure this instance of Oracle Configuration Manager manually in order for it to function properly.
Related Topics
Installing Siebel Enterprise Server Components and the Siebel Web Server Extension
Process of Removing Configuration Data
