Siebel Installation Guide for Microsoft Windows > Verifying and Troubleshooting Your Installation > Troubleshooting Installation for the Siebel DatabaseThese topics provide suggestions for troubleshooting problems that you might encounter when installing and configuring the Siebel database. Troubleshooting Installation for the Siebel DatabaseTypically, problems during database installation result from insufficient storage space having been allocated, or from the installer having improper user privileges. Acceptable Errors for Installation of the Siebel DatabaseThe log files might include errors that are expected and benign. Compare any error messages found in the log files to the sample error messages in the errors.rtf file, which is located in the installation subdirectory for your database, for example, NOTE: Only one of each type of error occurring in a particular log file appears in the errors.rtf file. If you find errors that are not listed in the errors.rtf file, then correct the condition that caused the errors, and rerun the Upgrade Wizard. The wizard restarts from the point where it left off. Do not review only the error numbers because these might have changed following installation of a new driver version. Instead, compare the error descriptions to find out which are acceptable errors for this database. CAUTION: Although other errors are rarely encountered, this review is critical. Certain errors, such as a failure to create indexes, might result in performance problems or anomalous behavior in Siebel Business Applications. You can view a log summary generated using the logparse utility. For more information, see Siebel Database Upgrade Guide. Troubleshooting Siebel Repository Import for the Siebel DatabaseTypical problems that can occur at this stage are shown in Table 18. These errors might appear in the log files produced by the Siebel Repository import process. |
| Siebel Installation Guide for Microsoft Windows | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
