Siebel Field Service Integration to Oracle Real-Time Scheduler Implementation Guide > Mapping Definitions > Mapping Definitions That Synchronize a Status >
Mapping Definitions That Synchronize a Shift, Break, or POU
Table 84 describes mapping definitions that synchronize a shift, break, or POU. The Siebel CRM fields in Table 84 reside in the Integrated Shift Break POU business component. The Oracle Real-Time Scheduler fields reside in the Shift, Break, or POU component.
Table 84. Mapping Definitions That Synchronize a Shift, Break, or POU
Oracle Real-Time Scheduler |
Field Name |
Parent Element |
Field Name |
EntityReferenceID |
ShiftID |
Status |
boStatus |
Shift |
ShiftID |
crewName |
TechnicianID |
DueDate |
startDateTime |
EndTime |
completionDateTime |
EntityReferenceID |
taskId |
Type |
Value is hardcoded as SHIFT_BREAK in FMW. |
languageCode |
Value is set in FMW after looking up in the DVM. |
