Siebel Field Service Integration to Oracle Real-Time Scheduler Implementation Guide > Appointment Booking Integration > Integration Flows That Book an Appointment >
Integration Flow That Confirms an Appointment
The integration flow to confirm an appointment is the same as the flow to book or reschedule an appointment illustrated in Figure 4 except for the following differences:
- Siebel CRM makes a Web service call to the Confirm_Appointment method of the ABSService Web service.
- To confirm the chosen slot, the BPEL flow calls the M1-MaintainActivityByHost Web service method of Oracle Real-Time Scheduler.
- The BPEL flow sends the reply that it receives from Oracle Real-Time Scheduler to Siebel CRM. The reply from Oracle Real-Time Scheduler can be a success or failure.
For more information, see Integration Services and Mapping Definitions That Manage an Appointment. DVM That Confirms an Appointment
Table 5 describes the DVM to confirm an appointment. For more information, see Configuring Domain Value Maps.
Table 5. DVM That Confirms an Appointment
SBL_ORS_Parameter_Definition.dvm |
This integration uses the following DVM parameters:
- ORS-Confirm Slot MaxCost
- ORS-Confirm Slot MaxCost-<SRV_REGION_NAME>
If SRV_REGION_NAME is missing, then this integration uses only ORS- Confirm Slot MaxCost.
- ORS-FindShift
- ORS-FindShift-<SRV_REGION_NAME>
If SRV_REGION_NAME is missing, then this integration uses only ORS-FindShift.
DVM- SBL_ORS_Endpoint_Definition.dvm |
This integration uses the Activity Maintenance DVM parameter. |
