Siebel Territory Management Guide > Setting Up Siebel Territory Management > Process of Setting Up Siebel Territory Management > Verifying Enterprise Data for Siebel Territory ManagementSiebel Territory Management uses data that has probably already been entered in your Siebel Business applications, such as accounts and contacts. You should verify that this data has been entered and is available for Siebel Territory Management. This task is a step in Process of Setting Up Siebel Territory Management. Table 4 summarizes the enterprise data used by Siebel Territory Management. |
| Siebel Territory Management Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
