Siebel Territory Management Guide > Setting Up Siebel Territory Management > Process of Setting Up Siebel Territory Management > Setting Up Divisions and Positions for Siebel Territory ManagementIn Siebel Territory Management, divisions are used to represent sales forces. Typically, you want to create a division for each of your sales forces. For example, a pharmaceutical company might create three divisions, one each for the neurology, cardiovascular, and oncology pharmaceutical sales forces. Positions are assigned to the divisions. These positions represent the employees in your sales force. Typically, you have one position for each employee in your sales force. (An exception to this might be if two part-time employees share a full-time job.) If your employees already use Siebel business applications, appropriate divisions and positions are probably already set up. See Siebel Security Guide for detailed information about creating divisions and positions. NOTE: When you create positions (and elsewhere on the UI), you see a field called Territory; this field is not related to Siebel Territory Management. This task is a step in Process of Setting Up Siebel Territory Management. |
| Siebel Territory Management Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
