Siebel Territory Management Guide > Setting Up Siebel Territory Management > Process of Setting Up Siebel Territory Management > Setting Up a Territory HierarchyTo set up the territory hierarchy, you create the record for the territory hierarchy, then assign the hierarchy to the division, and then add the territory records. At this stage, you create the territory records and can give them names that reflect geographic areas. However, you do not define specific postal codes (or geo zones); you define this specification later as part of the territory alignment. For example, you might create a territory record once, create a new territory node for it every six months, determine its boundaries when you do major alignment, and then adjust its boundaries monthly in a minor alignment. NOTE: For information about creating territories through bulk loading, see Using Siebel Enterprise Integration Manager with Siebel Territory Management. This task is a step in Process of Setting Up Siebel Territory Management. To create a territory hierarchy and territory records
| Siebel Territory Management Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
