Testing Siebel Business Applications > Functional Test Object Reference > SiebCalculator ObjectThe SiebCalculator object provides methods and properties that allow you to manipulate a calculator control in a test automation environment. ParentThe SiebCalculator object is a child of the SiebApplet Object, SiebList Object, and SiebCurrency Object. TypeThe SiebCalculator object is one of the Complex Control Objects. EventsThe SiebCalculator object has the following events. MethodsThe following method is available from the SiebCalculator object: For a description of this method, see SiebCalculator Methods. PropertiesThe SiebCalculator object has the following properties.
| Testing Siebel Business Applications | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
