Siebel Database Upgrade Guide > Upgrading the Siebel Database > Copying Ancestor RepositoriesUse this task to copy the ancestor repositories before beginning your upgrade. Ancestor repository files are located in an Ancestor Repositories media directory that you access from Oracle Software Delivery Cloud. You can also obtain them from My Oracle Support. The ancestor repository relevant to your upgrade is the Siebel repository that was shipped with the Siebel CRM release that you are upgrading from. It contains none of your customizations. NOTE: This guide describes upgrading to Siebel Innovation Pack 2015, Patchset 5 or later (Siebel CRM version 15.5 or later). Although Siebel CRM version 15.0 (Siebel Innovation Pack 2015) is available on Oracle Software Delivery Cloud, Siebel CRM version 15.5 or later (Patchset 5 or later) and the associated ancestor repository media are available only on My Oracle Support. Use the following procedure to obtain Siebel CRM Version 15.5 Ancestor Repository media. To copy the ancestor repositories
| Siebel Database Upgrade Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
