Siebel Database Upgrade Guide > Upgrading the Siebel Database > Changing the Siebel Database Configuration Utilities LanguageEnvironments: Development, production test, production. Platforms: Windows, UNIX, IBM z/OS. The Database Configuration Utilities launch in the language selected when you ran the Siebel Enterprise Server Installer. You can change the language in which the utilities run, if desired, from the language chosen during installation. To change the Database Configuration Utilities language, see the Siebel Installation Guide for the operating system you are using. If you want an additional language to appear in the language list in the Database Configuration Utilities, then you first must install the appropriate language pack on the database server and on the Siebel Server. For information about installing additional language packs, see the Siebel Installation Guide for the operating system you are using. Related Topics |
Siebel Database Upgrade Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
