Siebel Database Upgrade Guide > Siebel Database Upgrade Planning > About Upgrading Your RDBMS in the Siebel EnvironmentEnvironments: Development, production test, production. If your currently installed RDBMS version is not supported in the new release, then you must upgrade your RDBMS before performing the Siebel database upgrade. For information on supported RDBMS versions, see the Certifications tab on My Oracle Support. If your currently installed RDBMS version is supported in the new release, and you plan to upgrade your RDBMS, then you can do so before or after upgrading your Siebel database. The following guidelines and requirements are for planning your RDBMS upgrade. NOTE: When you upgrade the RDBMS, also be sure to upgrade your client database connectivity software. See the Certifications tab on My Oracle Support. Oracle DatabaseThe following guidelines and requirements are for planning your upgrade on Oracle Database.
IBM DB2The following guidelines and requirements are for planning your upgrade on IBM DB2. |
Siebel Database Upgrade Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
