Siebel Database Upgrade Guide > Siebel Database Upgrade Planning > About Database Sort Order in the Siebel EnvironmentEnvironments: Development, production test, production. Sort order (also called collation sequence) is specified during the initial installation of a database and defines the way in which the database sorts character data when executing queries. Sort order support depends on both the code page of the database and whether it is used in a development or a production environment:
The settings for binary sort order are unique for each database platform. For Siebel language support, Unicode support, and legacy code page support, see 1513102.1 (Article ID) on My Oracle Support. Sort Order Considerations for Siebel DatabasesIf your deployment requires that you use a nonbinary sort order (for example, if your local language does not use binary sort order), then you must consider several functional limitations that particularly affect development environment upgrades. If these limitations are unacceptable, then consider re-creating your database to use binary sort order. However, be aware of these considerations:
For Siebel language support, Unicode support, and legacy code page support, see 1513102.1 (Article ID) on My Oracle Support. |
| Siebel Database Upgrade Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
