Siebel Database Upgrade Guide > Performing the Siebel Incremental Repository Merge > Process of Performing an Incremental Upgrade of the Siebel Database from Siebel CRM Version 8.1.1.x and 8.2.2.x (SIA Repository) and Version 15.0 >
Requirements for Running the Siebel Database Configuration Wizard on Windows
This task is a step in Process of Performing an Incremental Upgrade of the Siebel Database from Siebel CRM Version 8.1.1.x and 8.2.2.x (SIA Repository) and Version 15.0. Do the following:
- Collect the information that the Siebel Database Configuration Wizard requires.
For more information, see Preparing to Run the Siebel Database Configuration Wizard.
- If your Siebel Server is installed on Windows, then start the Siebel Database Configuration Wizard from the computer where Siebel Tools is installed.
The merge process automatically starts Siebel Tools to execute the incremental repository merge.
- If the Siebel Enterprise server is not installed on the same computer as Siebel Tools, then map a network drive from the computer where Siebel Tools is installed to the computer where Siebel Enterprise Server is installed. Use this mapped drive to specify the location of the Siebel Server when you run the Siebel Database Configuration Wizard.
