Siebel Database Upgrade Guide > Performing the Siebel Incremental Repository Merge >
Process of Performing an Incremental Upgrade of the Siebel Database from Siebel CRM Version 8.1.1.x and 8.2.2.x (SIA Repository) and Version 15.0
Environments: Development, production test, and production. The tasks in this process enable you to merge customizations in the Prior Customer Repository (your current repository) with the New Customer Repository (the repository in the new Siebel CRM release). This process covers upgrades from Siebel CRM version 8.1.1.x and 8.2.2.x (SIA repository) and Siebel CRM version 15.0. To perform incremental repository merge on your Siebel repository, perform the following tasks:
- Preparing to Run the Siebel Database Configuration Wizard
- Requirements for Running the Siebel Database Configuration Wizard on Windows
- Running the Siebel Database Configuration Wizard on Windows
- Running the Siebel Database Configuration Wizard on UNIX
- Preparing to Start the Siebel Upgrade Wizard
- Preparing to Restart the Merge
- Restarting the Merge
- Starting the Siebel Upgrade Wizard
- Stopping the Siebel Upgrade Wizard on Windows
- Stopping the Siebel Upgrade Wizard on UNIX
- Executing the RUNSTATS Command on Oracle Database During the Pause Following New Repository Creation
- Executing the RUNSTATS Command on IBM DB2 During the Pause Following New Repository Creation
- Executing the RUNSTATS Command on Microsoft SQL Server During the Pause Following New Repository Creation
