Siebel Database Upgrade Guide > Performing the Siebel Incremental Repository Merge > Process of Performing an Incremental Upgrade of the Siebel Database from Siebel CRM Version 8.1.1.x and 8.2.2.x (SIA Repository) and Version 15.0 >
Restarting the Merge
This task is a step in Process of Performing an Incremental Upgrade of the Siebel Database from Siebel CRM Version 8.1.1.x and 8.2.2.x (SIA Repository) and Version 15.0. To restart the merge
- Restore the database to the state of the backup taken before the merge.
You must have already executed database statistics.
- Review the irm_sav_file.ssf file located in
SIEBEL_TOOLS_ROOT\bin. The State value should equal 7 (State=7). If it is any other value, then you must change it to 7 before starting the incremental repository merge again.
- Do one of the following:
