Siebel Database Upgrade Guide > Performing the Siebel Incremental Repository Merge > Process of Performing an Incremental Upgrade of the Siebel Database from Siebel CRM Version 8.1.1.x and 8.2.2.x (SIA Repository) and Version 15.0 >
Starting the Siebel Upgrade Wizard
This task is a step in Process of Performing an Incremental Upgrade of the Siebel Database from Siebel CRM Version 8.1.1.x and 8.2.2.x (SIA Repository) and Version 15.0. Use this procedure to start the Siebel Upgrade Wizard. To start the Siebel Upgrade Wizard
- Navigate to the following directory:
- Windows:
SIEBEL_ROOT\bin
- UNIX:
$SIEBEL_ROOT/bin
- Enter the following command:
- Windows:
siebupg /m master_UPGRADEOPTION_ENVIRONMENT_VERSION.ucf
- UNIX:
srvrupgwiz /m master_UPGRADEOPTION_ENVIRONMENT_VERSION.ucf
In these commands, UPGRADEOPTION_ENVIRONMENT_VERSION is the portion of the upgrade configuration file name that lists the upgrade process, the upgrade environment, and the Siebel CRM release (version) from which you are upgrading. The file is located in SIEBEL_ROOT\bin (UNIX: $SIEBEL_ROOT/bin).
Numbers like the following examples are used for the Siebel CRM release portion of the file name:
- 811sia
- 81114
Table 28 lists an example of the file names for an upgrade from Siebel CRM version 8.1.1 (SIA).
Table 28. Example Upgrade Configuration File Names for Upgrade from Siebel 8.1.1 (SIA)
Development environment upgrep |
master_upgrep_dev_811sia.ucf
Development environment upgphys |
master_upgphys_dev_811sia.ucf
Production environment upgrep and upgphys |
master_upgrep_prod_811sia.ucf
Table 29 lists an example of the file names for an upgrade from Siebel CRM version 8.1.1.11 (SIA).
Table 29. Example Upgrade Configuration File Names for Upgrade from Siebel 8.1.1.11 (SIA)
master_upgrep_dev_81111.ucf
master_upgphys_dev_81111.ucf
master_upgrep_prod_81111.ucf
- To begin the upgrade, click OK (Windows), or press Enter (UNIX).
The Siebel Upgrade Wizard will notify you when the upgrade process is complete.
