Siebel Database Upgrade Guide > Performing the Siebel Incremental Repository Merge > Process of Upgrading the Siebel Development Environment from Siebel CRM Version 8.1.1.x (SIA Repository) > Reviewing Siebel Repository Object Property ConflictsThis task is a step in Process of Upgrading the Siebel Development Environment from Siebel CRM Version 8.1.1.x (SIA Repository). Use this task to review Siebel Repository object property conflicts. Environments: Development environment only. Platforms: Windows, UNIX, and IBM z/OS. You can change how repository object property conflicts are resolved during the repository merge. How Repository Object Property Conflicts OccurNOTE: Use the Hierarchical Reports feature in Siebel Tools to learn what conflicts might have occurred, and to help identify areas to target for regression testing. For more information on this feature, see Using Siebel Tools. You cannot resolve conflicts from the report, but you can use the report to identify where to target regression testing and what conflicts have occurred. The repository merge compares repository object properties in the Prior Siebel Repository, Prior Customer Repository, and New Siebel Repository. When the value of an object property is different in all three repositories, an object property conflict exists. This conflict occurs when you have changed the value of an object property in the Prior Customer Repository, and the value of this property has also changed in the new release (New Siebel Repository). An object property conflict does not occur if you changed the value of an object property in the Prior Customer Repository, and the object property value did not change in the new release. When a conflict does not happen, the merge process transfers the changed value to the New Customer Repository. The merge process resolves object property conflicts by referring to the setting of the object's Standard Win property. For the majority of repository objects, the merge process resolves conflicts by using the object property value in the New Siebel Repository. Do not change the setting of the Standard Win property. Reviewing Object Property ConflictsYou can review and change how object property conflicts were resolved using the Application Upgrade Attribute List view in Siebel Tools. The Attribute Differences List in the view includes the following columns:
Related Topics |
Siebel Database Upgrade Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
