Siebel Database Upgrade Guide > Performing the Siebel Incremental Repository Merge >
Process of Upgrading the Siebel Development Environment from Siebel CRM Version 8.1.1.x (SIA Repository)
The tasks in this process enable you to perform incremental upgrade of your Siebel development environment from Siebel CRM version 8.1.1.x.
Environments: Development environment only.
For more information on Siebel Database Configuration Wizard parameters, see Preparing to Run the Siebel Database Configuration Wizard. For information on executing the Siebel Database Configuration Wizard, see Running the Siebel Database Configuration Wizard on Windows.
Perform the following tasks:
  1. Upgrading the Siebel Database Schema
  2. Executing Incremental Repository Merge on UNIX
  3. About Siebel Repository Merge Errors
  4. Reviewing the Siebel Repository Merge Log Files
  5. Reviewing the Hierarchical Merge Report
  6. Reviewing Siebel Repository Object Property Conflicts
  7. Reviewing Log Files for All Upgrades
  8. Reviewing Conflicts at the Attribute Level
  9. Marking Conflict Resolution as Complete Using Siebel Tools
Siebel Database Upgrade Guide Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices.
