Siebel Database Upgrade Guide > Performing the Siebel Incremental Repository Merge > Process of Upgrading the Siebel Development Environment from Siebel CRM Version 8.1.1.x (SIA Repository) > About Siebel Repository Merge ErrorsThis task is a step in Process of Upgrading the Siebel Development Environment from Siebel CRM Version 8.1.1.x (SIA Repository). Use this task to review Siebel Repository merge log files. Environments: Development environment only. Platforms: Windows, UNIX, and IBM z/OS. Acceptable and Unacceptable ErrorsTo determine whether the repository merge was successful, review the merge log files. The merge is successful if it completes without unacceptable errors:
Merge errors are displayed in the Upgrade Applications Objects List view in Siebel Tools. Additional details on merge errors are located in the incremental repository merge log file:
Each time you run the merge process, the name of the IRM_merge0.txt file is incremented, for example, to IRM_merge1.txt. Causes of an Incomplete Merge ProcessIf your repository merge process terminates and is flagged as Incomplete, then navigate to the Screens menu in Siebel Tools, and choose the Application Upgrader menu item. The most common reasons for its failure are as follows:
If the repository merge is terminated and flagged as Incomplete, then restart the incremental repository merge. For more information, see Process of Meeting the Requirements for an Incremental Upgrade to Siebel CRM Version 15.5 or Later, Using the Incremental Repository Merge. |
| Siebel Database Upgrade Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
