Siebel Database Upgrade Guide > Performing the Siebel Incremental Repository Merge > Process of Upgrading the Siebel Development Environment from Siebel CRM Version 8.1.1.x (SIA Repository) > Executing Incremental Repository Merge on UNIXThis task is a step in Process of Upgrading the Siebel Development Environment from Siebel CRM Version 8.1.1.x (SIA Repository). Use this task to execute incremental repository merge on UNIX. Incremental repository merge is started automatically on Windows, but on UNIX you must initiate the process manually. You begin executing the incremental merge when the Upgrade Wizard pauses and notifies you to execute the manual merge. To execute incremental repository merge on UNIX
If the merge fails, see Requirements for Restarting the Incremental Repository Merge. |
| Siebel Database Upgrade Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
