Table 30. Steps That the Siebel Upgrade Wizard Executes
verify_siebel_ver.sql |
Verifies whether the correct Siebel CRM version (from which you are upgrading) was selected when the Siebel Database Configuration Wizard is started. |
If this step stops because of an error, then it was because the wrong Siebel CRM version was selected during the launch of the Database Configuration Wizard. Select the Current Siebel Version as explained in Table 27. |
- Verify Repository Name
rename_existing_repositories.sql |
Renames the Siebel Repository to Prior Customer Repository. |
None. |
- Drop Interface tables
dropif-db.sql |
Removes all Siebel Enterprise Integration Manager tables. |
None. |
- Drop triggers
trigdrop-db.sql |
Removes all dynamically created triggers. |
None. |
- Remove database-level functions and procedures
drop_db_func_proc.sql |
Removes the exchange rate function: exrate. |
None. |
- Prepare for table creation
pret_irm.sql |
Performs DDL operations, such as adding columns to tables. Performs DML operations, such as revising date formats. |
None. |
- Create and update tables
ddlimp utility ddl.ctl as input |
The ddl.ctl file specifies the structure of tables to be created or updated. |
None. |
- Prepare for index creation
preschm_irm.sql |
Performs DML operations. Moves data between tables. Changes the data in the existing fields, depending on the specified conditions. |
None. |
- Create indexes
The input file specifies the structure of indexes to be created. |
None. |
- Import seed data
dataimp utility seedupg0.inp as input seedupg1.inp as input seedupg_locale.inp as input |
Before importing seed data, the dataimp utility deletes the existing seed data. The three seedupg files contain filters that the dataimp utility uses to prevent the deletion of seed data that you have modified or seed data that meets specified criteria. Unmodified seed data has a last update date (LAST_UPD) of 1980-01-01. The dataimp utility does not delete records in which the last update date (LAST_UPD) is later than this date. |
None. |
- Upgrade data after seed data import
upg_data_afterseed.sql upg_data_afterseed_sia.sql |
Updates existing seed data if any new columns have to be populated. |
None. |
- Set system pref for Codepage DB
set_codepage.sql |
Sets the database code page in the S_SYS_PREF table. |
None. |
- Set system pref for unicode DB
set_unicode.sql |
Sets the Unicode code page to UTF-8 in the S_SYS_PREF table. |
None. |
- Update version component information
upd_upgcomp.sql |
Updates the S_UPG_COMP table with the product release level. Also updates the location of the SRF file. The S_UPG_COMP table stores version information for application executables. |
None. |
- Run Oracle-specific DDL commands
ddlora.sql |
Creates Oracle-specific DDL information, such as default storage parameters for docking objects, repository objects, and seed objects. |
None. |
- Update Siebel database version
update_ver.sql seeduver.sql |
The update_ver.sql script creates a temporary table, S_APP_VER_TEMP, which contains new version information for the database schema. The seeduver.sql script updates the S_APP_VER table with this information. |
None. |
- Export Prior Customer Repository
repimexp utility Export Prior Customer Repository |
Exports the existing Prior Customer Repository to create New Customer Repository. |
None. |
- Import Prior Siebel, New Siebel and New Customer repositories in parallel
repimexp utility Import the Prior Siebel Repository, New Siebel Repository, and New Customer Repository. |
Imports the Prior Siebel Repository, New Siebel Repository, and New Customer Repository in parallel to the repository tables. |
If this step produces an error while creating the New Customer Repository, check the log file in: SIEBEL_ROOT\siebsrvr\log\upgrade_path\output). For Oracle Database: If you receive an error similar to the following, then you must restart the upgrade from the previous step Export Prior Customer Repository by changing the state.log of that step to Incomplete. Error message: [DataDirect][ODBC Oracle driver][Oracle]ORA-12899: value too large for column "S_ACCELERATOR"."INACTIVE_FLG" (actual: 4, maximum: 1)
- Install SQL packages
seeduver.sql |
Verifies that correct versions are set in the S_APP_VER table. |
None. |
ifstrg.sql |
Sets the storage parameters for Siebel Enterprise Integration Manager tables. |
None. |
ifindxstrg.sql |
Sets the storage parameters for Siebel Enterprise Integration Manager table indexes. |
None. |
pkgseq.sql |
Adds a suffix to row IDs in the S_SEQUENCE table. Ensures that row IDs are unique. The pkgldel.sql script defines s_txn_log_del_proc. The procedure periodically deletes transactions from the S_DOCK_TXN_LOG file. It also deletes rows from the S_DOCK_TXN SET table. This action prevents the need for a large rollback segment. |
None. |
trgreset.sql |
Ensures that denormalized rows in the S_TERR table have the correct values. |
None. |
ddlseq.sql |
Sets the sequence numbers for the specified tables. |
None. |
pkgvis.sql |
Creates a function that modifies how Oracle Optimizer performs the visibility check. |
None. |
- Create temporary indexes for merge performance
crt_temp_indexes_merge.sql |
Creates temporary indexes to improve the merge performance. |
None. |
- Take backup of the Siebel database and update database statistics
None |
Pauses the Siebel Upgrade Wizard to enable a database backup and the execution of database statistics before the merge. |
At this point in the upgrade, back up the database, and execute database statistics, then click Yes to continue the upgrade. To stop at this step and restart the wizard later, click No. To resume the upgrade, see Preparing to Start the Siebel Upgrade Wizard. |
- Execute Incremental Repository Merge
siebdev |
Starts the incremental repository merge automatically for Windows. If you are using a Windows computer and Siebel Tools is installed for Siebel Enterprise servers in UNIX environment, then you must perform this step manually. |
For UNIX or Linux: You must execute the incremental repository merge process manually. (On Microsoft Windows, incremental repository merge starts automatically.) See Executing Incremental Repository Merge on UNIX. |
- Generate Merge Report
MergeReport.jar |
Generates the hierarchical merge report in HTML format. Also creates the file IRM_Merge*_ERROR.txt in SIEBEL_TOOLS_ROOT\log, which contains only the errors that are present in the IRM_Merge*.txt file. For more information about the hierarchical merge report, see Reviewing the Hierarchical Merge Report. |
For UNIX or Linux: You must generate the hierarchical merge report manually, by running MergeReport.bat. Typically, you run this report after running incremental repository merge. (On Microsoft Windows, this report runs automatically.) |
- Upgrade history
store_history.sql |
Stores the upgrade history in the S_INST_UPG_HIST table. |
None. |
