Siebel Database Upgrade Guide > Performing the Siebel Incremental Repository Merge > Process of Upgrading the Siebel Development Environment from Siebel CRM Version 8.1.1.x (SIA Repository) >
Reviewing Conflicts at the Attribute Level
This task is a step in Process of Upgrading the Siebel Development Environment from Siebel CRM Version 8.1.1.x (SIA Repository). Use this task to review conflicts at the attribute level.
Platforms: Windows, UNIX, and IBM z/OS.
For more information on review conflicts, see Reviewing Siebel Repository Object Property Conflicts.
To review conflicts at the attribute level
  1. In Siebel Tools, from the Screens menu, choose Application Upgrader, and then Application Upgrade Attribute List.
    By default, you can see only the critical conflicts in the Application Upgrades Attribute differences screen. You must review the critical conflicts. To view informational conflicts, right-click and select Show Non-Critical Conflicts. Noncritical conflicts include conflicts of attributes, such as Sequence number, Comments, Layout, and so on.
  2. In the Application Upgrades list, select the record of the successful merge.
  3. In the Attribute Differences list, click Query.
  4. In the Attribute Differences list, click in the Conflict field so that a check mark appears.
  5. Press Enter to run the query.
    The query displays a list of all object properties in which there is a conflict.
  6. For each record, review the entry in the Resolution field.
  7. To change the resolution, click in the Override field.
    A check mark appears that changes the value of the object property in the merged repository. Avoid overriding conflicts for the following object properties. Review the following properties in the upgraded application before changing them: Left, right, top, height, and width.
Siebel Database Upgrade Guide Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices.
