Siebel Database Upgrade Guide > Performing the Siebel Incremental Repository Merge > About Migrating the XML Manifest Data for Siebel Open UI from Previous Releases to the New Manifest Data in the Database > Checking the Post-upgphys Verification ProcessAfter the upgphys upgrade is completed, check the oui_manifest.log file located in Checking for Database ErrorsUse the following method to check for database errors.
Checking for Application Errors |
Siebel Database Upgrade Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
