Siebel Database Upgrade Guide > Performing the Siebel Incremental Repository Merge > About Migrating the XML Manifest Data for Siebel Open UI from Previous Releases to the New Manifest Data in the Database >
File Selection Rules
Table 35 shows file selection rules.
Table 35. File Selection Rules
UI Object Record Values
Oracle (Siebel?) Record Present
User Created Record
File Selection Rule
Type = 'Application' and Usage Type = 'Common'
Yes
No
All files against all winning expressions under the Oracle supplied UI Objects record are aggregated and downloaded to the browser.
Yes
Yes
All files against all winning expressions under both the Oracle supplied and user entered UI Objects record are aggregated and downloaded to the browser.
Usage Type != 'Common'
Yes
No
The file against the first winning expressions under the Oracle supplied UI Objects record is downloaded to the browser.
Yes
Yes
The file against the first winning expressions under the user entered UI Objects record is downloaded to the browser.
Siebel Database Upgrade Guide Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices.
